USB2 External Hard Drive
bigoman
37
I plan on purchasing an external hard drive to house my media files (videos, music, etc) but I like eSATA and Firewire ports.
I was wondering if the transfer rate on USB 2 is fast enough such that I can watch things like videos straight off the external hard drive.
Thanks in advance
lobbyone
1,416
Yes, you can watch videos, transfer files or listen to music with an external USB2.0 drive. The transfer rate is 480Mbps i think, or is it 480MBps?
corkyg
Elite Member | Peripherals
27,370
240
It is up to 480 Mbps (megabits per second.)
shadowjack
43
The answer is that it depends.
For having mocked the gods (don't ask) I was condemed, for a thankfully brief period of time, to make money editing wedding videos. (No, you don't want to know how bad that is. No, you REALLY don't want to know.) The only good thing to come out of it was I learned that USB and Firewire are not equal for video work: Firewire kicks its ass.
The problem is that when you're moving lots of data around, either pushing it out of your machine to do drive imaging, or sucking it in to do video playback or editing (MP3 playing is fairly low bandwidth), the
USB controllers, in my experience, saturate quickly. So all those fancy benchmarks saying the two are equivalent don't do sustained transfers. If you look at the comparisons, you'll find that Firewire consistently beats USB when you're doing moving lots of data. (Oh, and formatting was a lot faster with Firewire -- I tried it both ways -- which sort of surprised me.)
I sort of doubt that you'll have problems watching movies, because this is still fairly low bandwidth, all things considered. It's not like using a non-linear editing package (Premiere, Vegas, FCP) which can really stress out your disk bandwidth.
But, at the same time, you can get an external drive case which has both USB 2 and Firewire at a very small premium over the USB 2 only case, so there's no reason to not get Firewire. (SATA is comparable to Firewire, and the price of SATA drives hits parity with PATA all the time, at least when they're one sale or with a rebate...)
Buy one with both interfaces, try them out, and you'll know for the future.
azzameae
17
Firewire is definitely superior to USB in my experience with external hard drive. Another thing that you might want to consider if you like to frequently use external disks is e-sata. It will be very fast and stable and is fairly easy to implement given the right equipment, though it can cost quite a bit.
