usb2.0 printer and usb1.1 print server any problems?
country2
598
4
hello,I've got a Epson Stylus Photo R320 printer (usb2.0) and I'm in the market for a print server.I've found 2 of them that supports all the features I need (mainly Bi-directional and DHCP)one is a usb 2.0 and costs around 88 dollars the other has about the same features but is a usb 1.1 and is about 40 dollars.If I get the usb1.1 would I have any problems or lag time while printing ?Is the extra money spent on the 2.0 really worth it?..thanks
qbek
110
I would go with 1.1. I do not think that it reduced bandwidth will have much of an effect for print jobs. I do not think you would notice any difference and even if there was any it probably does not justify almost double the price.
USB2.0 is much more important for peripherals that require higher bandiwdths like external HDs or burners.
Edit: I assumed your computer has USB2.0. If not, then definitely go with 1.1.
LED
6,127
It should work fine...just don't join the 1.1 on the same /hub or connecting port as it'll slow all the other devices down hooked with it.
country2
598
4
Thanks for the replies...Thats just what I thought but wanted approval here since this is the place with the most knowledgeable people..:)
