USB Wireless Hubs
mattg1981
957
My office is getting super cluttered and I have to move my big old all in one printer, which is usb. I was wondering if there was a simple little 4 port or so hub .. that was wireless, so I can put my printer in say my room, and have it still work.
I googled for some, but all I find is a usb wireless networking adapter.
Like said, I dont want it for networking, I just want something that I plug in my usb port in my computers usb port and then plug my printer into a wireless hub in a different room.
Any suggestions?
TechnoPro
1,727
I saw just such a product in a magazine several months ago. Can offer you no further details as I don't rememebr the brand.
However, what about a product like this? Pricey and perhaps overkill for what you need, but looks decent.
There's also this but it is not compatable with multi-function devices...
JackMDS
29,563
432
Yes you can do it through BlueTooth.
I personally consider it as a Waste.
If you have a small network or you planning one day to have one you better off using Ethernet rather than BlueTooth.
:sun:
Goosemaster
48,775
:sun:
Yeah. Ethernet is just plain better unless you need the freeom.
If you want the wireless conenctivity, try this.
Get a wireless bridge, and connect a switch behind it. I belive that they should let you use more than 1 MAC on wireless bride products.
Even easier would be to just buy a consumer router with a bridge built in. tHen just bridge the two networks and plug in your equipment to the routers built in witch.
OR
get a wired woruter, plug in your devicesto the built-in switch , and plug the WAN jack into a standalone wireless bridge.This might create problems however as routing Printer sharing (windows netowrking TCP/IP and UDP) are always routable to the WAN on many consumer routers.
