USB vs. ethernet
  • Thread starter Thread starter ku
  • Start date Start date
ku
I am getting cable soon (tonight/tommorow/soon!) and i wanted to know if i should use the USB port or buy a ethernet card.
Which is faster and more reliable?
Please respond with your comments... thanks!
I wouldn't use the 1.2 USB standard devices. If you were going to use USB, get the new 2.0 add-in card(s).
But, for connecting to the Internet and to other internal machines, I suggest you get either an Intel, 3Com, D-Link, or NetGear NIC. I would try to get an Intel or 3Com first. If they are too expensive (which in most cases they are), I would go for the others I mentioned.
EDIT: Sorry about that. DAMN KEYBOARD! :|:|
Unless:
1. You can not open your computer (or you need a hammer and a chisel to open it).
2. No way to find an empty PCI slot in your computer.
There is not even one reason to get USB (bedside the above).
