bradly1101
http://www.theinquirer.net/inquirer...heap-usb-type-c-cables-could-bork-your-device
The problem stems from the use of USB Type-C as a power source. The standard requires that a 3A supply be available through the cable. In order to do this, the correct resistor has to be present in the cable to control the amps being inputted. It's in the specification. It's not supposed to be optional.
In some cases, the wrong resistor is being used, or omitted entirely from connectors, and there's a risk that at best, your device won't charge, and at worst, it'll fry, explode, melt or grow sentient and turn on its master.
