USB sound card
stefs12
My 3.5 mm plug is stuck. I like to buy adapter so i can enjoy in good sound. I dont know, do are every usb sound card the same?
In some cases i see that have chip HS-100B, in some ALC4040. Can comeone told me, which is better?
Inexpensive USB sound devices are all pretty much the same. There's some high-end ones out there (like Creative), but you really shouldn't need to spend that much. Just look at the bestsellers at Amazon, and most of them are under $15. Just pick out one that has a lot of good reviews:
https://www.amazon.com/Best-Sellers-Electronics-External-Sound-Cards/zgbs/electronics/3015427011
Be sure to check Fake Spot to make sure the reviews aren't fake before selecting one:
https://www.fakespot.com/
I've personally had good luck with the Sabrent products I've bought like battery chargers and such, and they have one on that list at #11 for $7.99. Although in your area, the prices and availability could be different.
