Well I had a friend at my moms work resolder the hard drive wires, plugged it back in and wallah my sound is fine again. But this still is pretty annoying, as I might want to bring my extigy in the other room without bringing the hd along, since I'm too woried about breaking the wires off again (dont have spare $50 to waste on a good one). don't be like me and buy a crappy cintre case
One thing I do know is it doesnt have anything to do with which drive I am actually playing the files from. But when it is messed up some specific things always seem to mess up the sound. The shutdown sound always pops, opening device manager always causes pops. But when all is normal I have no problems. My usb HD drive obviously is USB 2, while the extigy is USB 1 so could this have something to do with it? But the weird thing is I don't believe I have them on the same usb channel anyways, I dont believe my laptop usb ports are shared in anyway since device manager lists 3 usb hubs and I have 3 ports am I correct? but then again it lists 2 usb host controllers, so that confuses me. if there are just two channels I still think they would be on seperate channels since two are on the side where I plug in my HD and I plug in the extigy in the back.
Also does this mean anything?
USB host controller 1 'advanced tab'
system reserved 10%
usb host controller 2 advanced tab
system reserved 11%
usb composite device (believe it is the extigy) 17%
Could I somehow force more bandwidth allocated? The extigy has its own power supply along with the hd, so I dont think it has anything to do with that. I do have it on a 12 foot monster usb cable, but I've heard it cut out on a 3ft cable just as much. Also have tried on a powered hub and not on a hub and that makes no difference. Sorry for such a long post but hopefully you will have some answers for me.  It kinda sucks trying to get a discontinued soundcard working, but it does seem to have a better dac then anything I own so I love it. Also fun running my cd/dvd player through it and still having computer audio mixed in.
