When I plug my USB flat bed scanner into one of the 2 'extra' USB ports, the ones that are on the PCI bracket that come w/ some mobo's and have a wire that plugs into the header on the mobo, it isn't seen by Windows XP. I have to plug them into the two main hard wired ports in the normal position on the I/O plate before the work.
It also rarely happens with my compactflash card reader, but I can unplug and plug it back in and it works on the extra USB ports. Doesn't work with the scanner. What's causing this?
