Modeps
alrighty, Ive tried a variety of things here to try and fix my problem. here it is:
My configuration is:
USBPort1 -> USB Microtek Scanner
USBPort2 -> USB Hub -> USB Optical Explorer Mouse
I have tried removing the hub and hooking the mouse directly to port2, but it dosent matter. After a short time, for some reason, my mouse's red glow, stops glowing and the mouse stops working, as well as the scanner. However, when the scanner is not attached, It works fine. I've disabled error checking in the device manager and done some other things that didnt work. do the new via drivers help out at all? im contemplating installing them.
Has anyone had these problems and fixed them? i would like to run my computer without having to unplug my scanner all the time. Thanks in advance.
