USB problem
macca40
USB Problem
the two USB ports on the back have stop working.been into bios and all ports are enabled front two work ok.
In device manager get yellow mark at side saying unknown device. yet both root hub and both host controller say these are working ok.
Any ideas to what the problem is.Re-installed win98se,run the board out of case.
M/B GA-7VTXE+
Thanks macca
Are you sure it's the ports that aren't working, or the device you have plugged into it? The "unknown device", if both the root hubs are showing up just fine, would be whatever device you've plugged in. If you didn't install drivers for the device before plugging it in, Windows won't be able to detect it properly.
