I have an asus av8 board and for some reason the via usb 2.0 drivers will not take. I have tried running the utility on uninstall then reinstall but when I plug in a memory stick it always gives a non2.0 message. any ideas? thanks
The drivers go in the OS - what are you using? Motherboards don't "take" drivers. If the USB ports are enabled in BIOS, and you are running XP, nothing else should be necessary
I have other HD's with xp pro installed and they run USB 2.0 . when I put this particular hd in ,it will not run usb 2.0 . The USB ports work but all run usb 1.0 or 1.1. I am using the same via driver package for all the HD's. When I plug in the memory stick I get a message---hi speed device plugged into non hi speed usb hub. I have tried manual install of drivers and have gotten nowhere. thank you
