USB problem with Gigabyte GA-880GA-UD3H AM3 board
GundamF91
1,827
I just got a Gigabyte GA-880GA-UD3H board, running together with Athlon II X4 640 3.0Ghz, and 2x2GB A-Data DDR3-1333 memory. It's not overclocked (yet), and everything seems to work fine. The only problem it seems is the USB detection after a "non-Windows" restart. By this I mean that when first powered on, the USB keyboard works fine. I can get into Gigabyte BIOS by hitting "DELETE" key. And I would change the load device, by setting loading from CD-ROM first. This way, I can get the system to load up Memtest86 and do tests. But I have discovered that once I exit out of Memtest86, the computer would restart as it should, but that time, the USB keyboard is no longer working. I could no longer hit DELETE or other keys again, and the boot would just keep on going. It'll either hit Memtest again since I still have the bootable Memtest disc, or if I pull out the disk, it'll go right into Windows 7. Everything else works fine, but this is bothering me that somehow the USB keyboard no longer works after this restart.
If was restarting computer using the Windows 7 command, then it works fine like usual.
Any idea on what's going on?
