Help?
I can't figure out the pins that came with a mid-tower case that I'm building here, with no documentation what-so-ever. Welp, you get what you pay for I guess, the case was $35.
Looking to hook it up to a K7S5A, so the typical USB pin configuration can be found there. (10 pins, arranged 2x5, with pin 9 missing.)
As for the case, the 2 USB ports in the front are connected to the mobo via a ribbon 8pins wide. Pins 1-3 (One of them is red, so it has to be #1) go to one 3pin plug and the pins are labelled as follows: #1) VCC, #2) DATA-, and #3 DATA+. #4 is a one pin plug labelled GND. The same applies for #5. #6-#8 is another 3 pin plug, labelled #6) DATA+, #7) DATA-, and #8) VCC.
Can anyone help me out here?
Thanks.
Thanks.
