USB or PCI Wireless Adapter -- What do You Recommend
JackMDS
29,556
431
I need a Wireless Card what should I get? http://www.ezlan.net/faq#wcard
I need a vehicle would should I get.
Do you need it for racing?
Do you have snow and need a 4WD ?
Do you need it for construction Work?
And so on, and so on.
JackMDS
29,556
431
Yap, If the PCI has no replaceable antenna, it sit a10" from the floor between the metal tower case and the wall in a room that is 30 feet away it is a very Good choice?????????????? :shocked: :shocked: :shocked:
Alternatively, if it has replaceable Antenna and the OP would have to pay $30 more for a coax and better Antenna it is Very Good choice too???????????? :shocked: :shocked: :shocked:
On the other end if every thing is in the same room would make more sense to shop by price coz USB, PCI, or a two cans string telephone, all would work.:thumbsup:
Phoenix97
16
My experience with one of those cheap $30 Airlink USB to wifi adapters is that they may drop the connection once or twice a day even if the signal quality's good. If you're using them in a machine with USB 1.1 ports, they'll rob your bus of some bandwidth... as example, a high end U160 SCSI hard drive gets its interface transfer rate reduced from 105 to 80MB/sec, while an older ATA/33 drive goes from 29 to 21MB/sec.
