usb mouse not working
Felonious
94
I just installed win 98se on a new drive
Usb is enabled in the bios
I installed intellieye software
installed via usb filter for 98
what am I missing?
Mytv
Banned
May 12, 2000
422
Simple as plug in play.
Do a recheck of the cords and if not reinstall the drivers and software.
wjones
2,396
I know some USB devices need you to install the software and driver first BEFORE you plug in the devices.
Felonious
94
I definitely installed the software first, and then, uninstalled and reinstalled. Not...
Everything looks good in device mgr. I don't know what else to do. It works fine on my other hard drive (same mouse, same OS)
buildingacomputer
281
Have you tried turning off the computer and then back on? I had a hard time installing an USB printer. No matter what I did, I could not get it recognized by the computer. In my case, cold boot solved the problem. Warm boot (control+alternate+delete) didn't work. You may want to try it.
miniMUNCH
4,159
You may have an IRQ conflict with another device in your system. Do other USB devices work on the same port? You can reassign your USB's IRQ in BIOS (I think) if it is an IRQ problem.
