USB Keyboad Adapter Issue
d4mo
I got this keyboard: http://www.madcatz.com/Default.asp?Page=151 to use for when I play WoW so I don't wear out my laptop keyboard. The problem is that the USB converter doesn't seem to work very well. It doesn't let you press more than key at a time. Like If I am holding in D and then press W it just keeps going as if I am only pressing D. I've tried it with a different keyboard and it does the same thing so I know it's the keyboard. So has anyone had any issues with Ps/2 to USB converters or know of any solutions?
I had this problem on another keyboard. It was simply a flaw with the input design. The company put out a patch just to fix it.
I suspect that Madcatz will do the same.
