Originally posted by: KenSr
How do you convert it?
I did a format and the only options were for FAT or FAT32.
Originally posted by: Peter
The physical drive never cares what you do with its storage sectors. Partition types and file system models happen several layers further above in the driver stack.
So if your OS lets you put an NTFS onto a removable storage device, you're set. NT/2K/XP let you do that - after you've used the Storage Manager to create a HDD style partition on it, not from the "format floppy" dialog.
It's just not as interchangeable with other systems as FAT is.
