i am afraid if you try that many option, you may actually fired you USB connection. I did and the board is still running well.
if u need help on the this i can help. give info on your front USB wire (+5v, +D, -D, -5V, ground, .... or color, .... 10 wires or 9 wires or 8 wires?) and we can go over this.
As for product, in the cableclub.com, any of the
6B439-B or the 6A439-A should work. They have a $1 on pricewatch.com but the product seems no the same. may have to call in. buy any said 2X5.
as long as the they are... should work.
Cable Pin Out
Pin Color what is does
1 Red + 5 Volt
2 White Port 0 Data -
3 Green Port 0 Data +
4 Black Ground
5 Black Ground
1 Red + 5 Volt
2 White Port 1 Data -
3 Green Port 1 Data +
4 Black Ground
5 Black Ground
I saw my local Best buy have USB connector for sale (forget the price, likely $12 or something)
follow the link for the official pinout. note the 1 and 2 on the picture of USB port. line up with the +5v or red. and the rest follow down. pin 9 on left is empty which is okay. (even pin 10 is not connected will be ok too, so u can get a 2X4)
