Usb gamepad controller for emulator rom
More expensive than the Logitech pads, but not better IMO. Unless you already have PS2 pads, that's not a good solution.
i've got the logitech dual action usb. got it for 15 bux on sale. it works great. very similar to a PS2 controller, but i've also heard plenty of good things about the ps2 usb adapter, especially if you're used to that.
I picked up a logitech wingman action pad for pretty cheap and works nicely. But the D-pad is clicky. The analog stick is not. There is no auto-fire button, and it does not have built-in penis vibration.
But a good pad nonetheless.
I like the MS Sidewinder Gamepad. Its simple, responsive and Windows supports it with no driver install needed.
