the answer is yes it is possible, but the MB needs to support booting to USB devices, ie cdrom/floppy. The drive will need to be partitioned, the partition made active and the OS loaded, doesnt sound difficult, and if all support is present it really isnt, but if the hardware support doesnt exist, it is impossible. I believe there is a tool on the hp website, i read about it... here i found the website it was on, it has links, and a discussion on this
