USB Flash Drive Replacement
kevnich2
I've had my sandisk 256mb drive for about 2 years and I'm curious about the life cycle of them. I keep all of my documents on this drive for portability and I really don't want to lose the documents simply because the drive has gone past it's life cycle and dies. Anyone have any idea how long a typical usb flash drive lasts and how often one should be replaced? Thanks in advance.
I heard anywhere from 1000-10,000,000 write cycles.. So.. um.. somewhere in the next 1 minute - 10,000 years.
Depending on the type pf flash memory, either 10k or 100k erase cycles PER block. Generally they will last for 5-10 years with daily usage. Data retention is longer if all you're doing is reading stuff thats already been written.
I'm considering getting a PNY 1gb disk. It'll be more than enough for all of my files. My drive hasn't died, I just didn't know if I should think about replacing it as it's getting to be a few years old now.
You should think about getting a new one just to get USB 2.0 support. Your current one is fine and isnt close to end of life, but is prolly dog slow.
Actually the one I have is the first sandisk USB 2.0 one they came out with. Actually picked it up the day it came out, but it's definately one of the older models. But I do think the newer ones are faster than mine, even if it is USB 2.0
Ideally, you should keep any documents you care about in at least two places(shouldn't be that hard to find a spare 256 megs on your HDD) so even if the drive dies, or as may be more likely, gets lost/crushed/stolen/etc. you'll only lose a day's changes. If you are doing few writes, it should last the 10 years or so that the cells are rated to retain data.
