USB flash drive mounts CDFS
NRaygun
131
I saw a neat USB flash drive trick - when I insert it into my laptop, it not only mounts the empty USB space but also mounts a CDFS image!
This is in Windows 2000.
Does anyone know how to partition a USB drive such that this is possible?
akira34
1,531
What flash drive do you have?? I've not had any of mine come up that way. Some of them have 'security' software/items on them that I usually get rid of pretty fast. I usually just format the drives so that they are better suited for what they will be used with/on. I've formatted a few for OS X and one or two for Windows (DOS format)... That makes the ones used under OS X mount faster and eject easier. Especially the larger ones (512MB)... Of course, for really large files, I use my external hard drives (laptop sized drives in enclosures not much larger than the drives). Comes in handy when you have a 40GB, 60GB and two 80GB drives readily available that only need to connect through a single port to get power and be used (FireWire port).
Anyway, I suggest doing a google search for the term it's using and read the hits...
