There is a device that has two connectors that attach to the ends of a cat5e cable that can extend a usb to 150 feet (supposedly). This is good. If this actually would work, I was then wondering if I can add a splitter to the other end to extend 2 or 3 or 4 at 150 feet.
What I am trying to do is connect my computer to our phone equipment via the USB ports on the panasonic phone equipment that is about 50-100 feet away. If the extender works, I have an extra cat5e cable at my desk going to the phone area, and wanted to put a splitter up there and connect to two different pieces of equipment (that do have their own power)
I asked the manufacturer, and got a funny response (see below). Whats the difference of using a splitter at the computer, or at the end of a cable, or at the end of this extender cable?
The item is "GUCE50". You can put that on google images and find it easily.
Their response is as follows:
It is difficult to say for certain, not knowing exactly what you are trying to
accomplish, but please take the following into consideration
1- The Extender will not supply power to the devices on the non computer end
2- If the devices on the other (non computer) end are powered, AND you are
using a relatively short USB cable you should be OK.
I would approach this carefully, you don?t have to worry about destroying
anything, but it appears as though you are trying to get something for
nothing which, in the computer world usually means it won?t work
IOGear Service Support.
Any help with this is appreciated.
