USB DSL modem losing connection
Davegod
My sister's having problems with the USB DSL modem and her laptop. Unfortunately I only have the info I've gained over the telephone (she's not exactly a tech geek, to say the least) and will be going over there next weekend to try to fix it.
the modem is a Acatel Speedtouch 330 (USB). The laptop is a HP thing, bought under a year ago but, well, she ignored my advice.
It seems she had been getting disconnected quite often for the last few weeks previously (worked fine before), but now it isnt even connecting properly. The ISP support reckon the username and pass is coming in garbled, that is when the connection makes it that long. They suggested getting a PCIe USB card, because apprently some USB just breaks after a while of doing what it is within spec?
The modem has two LED's, one for USB connection and one for DSL signal: the USB LED is rapidly alternating between green (good) and red (bad), the DSL LED stays green. Checking device manager showed it thinks the modem is getting it's 500mA, but she told me Device Manager was "flickering" - unplugging the USB cable stopped that. The modem is the only thing connected to USB, and the LED pattern doesnt fit in with the documentation troubleshooting[.PDF].
I'm tempted to think the ISP tech is about right and the problem's all in the USB hardware, but I find the thought of a brandname laptops USB being unable to cope with spec, plus inbetween the connection going from 'flakey' to 'effed' there was some nasty dialer spyware (i got her to remove it with adaware then suggested reinstalling speedtouch/isp software, then unaware of the prior connection issue)
Agree with your ISP tech - USB connections are unreliable on a sustained basis. They frequently just "let go."
Unless the laptop has a built-in modem, your best bet is a PCMCIA card - not USB.
PCMCIA DSL modem cards seem awfully expensive, and the relatively cheap ones I suspect are liable to be prone to other problems she's not going to be able to fix easily. Ditto for a router.
I'm now thinking how about a powered USB hub for about £10, and if the lappy's USB is damaged then a PCMCIA USB card for about £15.
BTW i fixed it just with drivers. Had to take a roundabout path (short version being: had to reinstall driver from an alternate source to be able to reinstall properly, then reinstall driver from alternate souce and reinstall over that the original driver). All A1 fine after that.
