defaultabuser
I have a recurring problem bugging my usb drive, but which also has affected one of my hard drives, too(that one ended up dead). With the hard drive, the drive itself started failing so that was at least part of the reason.
With the usb drive, here is the problem.
I can use the drive just fine 90% of the time. But every now and then, it will lock up, like during a long copy/move operation, and everything freezes and I have to power off. I should note that I do use a usb hub so there's that. And the hub is not even directly connected to the laptop it's connected to the cooling pad. But my other usb drives are ok, afaik, and they use the same setup.
The problem usb pen drive is a patriot 8GB, fat32 formatted drive. I did recently notice the dreaded "found" folder on this drive, that tells me the drive has lost some clusters somewhere. Important question: How do I know which of those cluster files in that folder go with which source files? Because I may want to delete the comprimised files.
Anyway, if I boot up spinrite, it tells me something like "this drive's size doesn't match the size of the drive according to the bios(int13) extension". (as best I can remember)
If I boot up testdisk, and analyze that drive it tells me something like "bad sector relative?position" next screen tells me word for word:
Disk 83 - 8015MB / 7643 MiB - CHS 974 255 63
The harddisk (8015 MB / 7643 MiB) seems too small! (< 8015 MB / 7643 MiB) Check the harddisk size: HD jumper settings, BIOS detection...
The following partition can't be recovered:
FAT32, 8011 MB / 7640 MiB
Code:
Partition Start End Size in sectors
FAT32 0 128 1 974 120 42 15646848(PATRIOT)
