- May 11, 2001
- 337
- 0
- 0
Thats right! I have an Intellimouse Optical on my Epox 8K7A. It was recently that I discovered that I needed to manually change my FSB from 100 to 133 in the BIOS if I was to have my CPU running at it's full 1400Mhz. But guess what? After I change that, my USB optical mouse is no longer detected, but will only detect a PS/2.
I went into the Integrated Peripherals in the BIOS and ENABLED USB Mouse Support, and USB Keyboard Support. Someone told me that I should enable USB Legacy, but there is no such option in the entire list, and I checked and double checked. I called MS tech support, and he thinks there could be something wrong with my motherboard, but he recommended that I reflash the latest BIOS.
Some body please help me with this issue. What must I do to properly configure my USB port to understand my Mouse once the FSB is set to the original 1400Mhz???
(Note: I know that the problem lies with the FSB, because I tried changing it back a few times to 100 (1050Mhz), and it always detects my USB mouse at that setting, but not at 133)
