USB Controller Driver for WinXP
lti
31
Anyone knows where I can get USB 2.0 drivers for Windows 2000/XP for download?
TheCorm
4,326
You may be able to goto Windows Update and look in the device drivers section....did you not get a drivers cd with the mainboard / PCI card??
If it's a USB 2.0 PCI card, check the chipset on it and goto whoever made the chipsets website, they may have downloads, you just need to kind the right ones for your chip number....you may be able to do the same for onboard...unless USB 2.0 is integrated into the southbridge....which is probably is thinking about it.
Corm
