USB: Can a USB hub be used on both PC and iMac?
Confused
14,166
A friend wants to know if they can use a normal USB hub on both a PC and an iMac.
I think it is possible, as USB is a universal standard, but PC World is selling both a USB hub for PC and a USB hub for iMac! Are they the same thing or are the two different?
Thanks in advance
Confused
ViRGE
Elite Member, Moderator Emeritus
167
Yes. USB is a universal standard, and that's all that matters. The only reason for the "difference" is probably because the iMac one is painted differently.
corkyg
Elite Member | Peripherals
27,370
240
Hardwarewise - no difference at all. My Belkin USB 2 hub is PC or Mac. Just different drivers.
ViRGE
167
Just as a side note, the only reason Corky would need drivers is because it's for USB 2. Both MacOS and Windows have built-in support for USB 1.1 hubs.
