Basically, I've been using a USB-connected cable modem for the time being and it has been giving me problems concerning file transfers in messengers and other problems as well as no one being able to connect to my computer at times. Since it is USB-connected, I can't do much because it doesn't show up in the "network connections" window. So I tried to connect it using the RJ-45 cable that came with the modem. At first I just reconnected it using that cable and put in the CD to install it, yet during installation it could not detect a connection between the modem and the computer for some reason. I tried to do several things like "repair" the connection and even tried giving it its own IP because it couldn't repair due to it not being able to connect to a DHCP server. Nothing has worked so far and I'm wondering what the problem is because I just want the ethernet connection to work out so I can actually edit it for future use. Thanks.
