- Sep 9, 2004
- 192
- 5
- 81
Pardon if this is a dumb question, but I guess I'm unsure how a hub like this one will work.
https://www.amazon.com/Anker-PowerI...01000026&sr=8-1&keywords=usb+3.0+hub+charging
It connects to the computer via one USB cord, which is apparently just plugs into a USB 3.0 port on your PC. So how can I use seven USB 3.0 devices all at the same time through one USB port on the PC? Does each drive show up as a different drive letter? Does it just slow all the transfer speeds down? It would have to, right? So copying data from drive 1 onto drive 2, while also copying drive 3 to drive 4, while also copying drive 5 onto drive 6..... it would all slow to a crawl (by USB 3.0 standards)? Surely plugging my seven devices into seven separate USB ports on the computer would yield better results?
