USB 3.0 Front Panel suggestion
e-drood
some users may be looking for usb 3.0 terminated with 20-pin motherboard connector
as i'm waiting for lian-li 20-pin adapter & lian-li & corsair front panel usb 3.0 accessories in hk, i have found following to have reasonable build quality:
cooler-master usb 3.0 adapter p/n RA-USB-3035-IN having correct usb 3.0 revision thick multi shielded/screened cables & (2) usb 3.0 ports
3.5 inch tray/frame - you must add side extenders to install in 5.25 front bay... pair of side extenders in hk 8-12hkd...
cable length measured from face of usb3"b" socket to 20-pin connector face is 82cm / say 32 inches & is long enough for asus m4e (lefthand edge 20-pin header to front panel in large full tower case (corsair obsidian 8XX)
i will install a ferrite near usb3"b" (each one) to prevent signal errors - i do same on longer e-sata cables also
yes price, in hk is 12.70usd or 98hkd -
only issue - 20-pin frame molded in black resin, instead of blue resin - usb3"b" tongues correctly molded in blue resin - function is good
this is genuine cooler-master, not counterfeit...
