USB 3.0 Flash Drive for Key Chain?
scooterlibby
I was looking around Newegg for a usb 3.0 flash drive with a loop for a key chain but didn't see one. Any suggestions? Thanks.
Thanks for the reply. I should have been more clear. Those get complaints about being really bulky. I'm hoping to find one that would fit more comfortably on a key chain. I don't need very high capacity either.
You're limiting yourself too much, requiring a 3.0 keychain drive.
A fast reading USB 2.0 is much more realistic and easier to find.
There simply aren't many PCs or USB drives that support USB 3.0 yet.
Then wait. USB3, right now, means more chips, which means bigger. You won't find small thumb drives with fast write speeds, and small ones with USB 3 are going to take awhile.
