USB 3.0 drive and USB 2.0 hub does not work puzzle
doug
259
So I am trying to use a USB 3.0 drive with a USB 2.0 powered hub. I don't care about the speed I just need the connectivity.
If I plug the Seagate USB 3.0 drive directly into the computer using a USB 2.0 cable it works.
If I put a powered USB 2.0 hub (tried two I have around) inline the LED comes on in the drive case but I don't see the drive show up on the computer.
Any ideas? Are there certain powered USB 2.0 hubs that don't like newer drives?
bbhaag
7,397
3,022
Does it show up in disk management but just as unallocated? If it's there maybe try assigning a drive letter to it.
doug
259
Thanks of the idea, it is a Linux system but I tried watch dmesg for a while and tried different ports.
For some reason it seems to reset a couple of times but then it started working, yay!
This is what I get when I plug it in directly:
[253337.428074] usb 2-3: new high-speed USB device number 23 using ehci_hcd
[253337.565473] scsi9 : usb-storage 2-3:1.0
[253338.565038] scsi 9:0:0:0: Direct-Access Seagate Expansion 0502 PQ: 0 ANSI: 6
[253338.566512] sd 9:0:0:0: Attached scsi generic sg2 type 0
[253338.573980] sd 9:0:0:0: [sdb] Spinning up disk.....ready
[253340.584720] sd 9:0:0:0: [sdb] 2930277167 512-byte logical blocks: (1.50 TB/1.36 TiB)
[253340.856779] sd 9:0:0:0: [sdb] Write Protect is off
[253340.856785] sd 9:0:0:0: [sdb] Mode Sense: 4f 00 00 00
[253340.857608] sd 9:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[253340.874729] sdb: sdb1
[253340.887227] sd 9:0:0:0: [sdb] Attached SCSI disk
USB hub being plugged in:
[254399.936284] usb 7-1: new full-speed USB device number 66 using uhci_hcd
[254400.104401] hub 7-1:1.0: USB hub found
[254400.106293] hub 7-1:1.0: 7 ports detected
Finally the drive itself into the USB HUB:
[254446.518305] usb 7-1.1: new full-speed USB device number 67 using uhci_hcd
[254446.696082] usb 7-1.1: not running at top speed; connect to a high speed hub
[254446.736416] scsi12 : usb-storage 7-1.1:1.0
[254447.741119] scsi 12:0:0:0: Direct-Access Seagate Expansion 0502 PQ: 0 ANSI: 6
[254447.742148] sd 12:0:0:0: Attached scsi generic sg2 type 0
[254447.762138] sd 12:0:0:0: [sdb] Spinning up disk.....ready
[254449.798143] sd 12:0:0:0: [sdb] 2930277167 512-byte logical blocks: (1.50 TB/1.36 TiB)
[254450.036181] sd 12:0:0:0: [sdb] Write Protect is off
[254450.036192] sd 12:0:0:0: [sdb] Mode Sense: 4f 00 00 00
[254450.039168] sd 12:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[254480.910077] usb 7-1.1: reset full-speed USB device number 67 using uhci_hcd
[254481.809128] sdb: sdb1
[254481.841127] sd 12:0:0:0: [sdb] Attached SCSI disk
[254513.961092] usb 7-1.1: reset full-speed USB device number 67 using uhci_hcd
Maybe this is a USB high-speed vs full-speed issue.
