Question USB 3.0 Cradle Type Male to Male Cradle Base Stand
bjlockie
177
I'm looking for this sort of thing that I can use my own cable.
I don't want it to have any attached cable.
It must be USB3 too.
Tech Junky
3,825
1,342
Ahhh.... the exact opposite of everyone else. Most of them come with 3-6 foot cables on them. I don't recall ever seeing one with a detachable cable though.
I found something but it was a USB-2 and kind of expensive.
Travel / hub / stand are some keywords I tried along w/ USB and then added 3 since you mentioned it. It's probably out there in the wild it's just a matter of figuring out how to word the search to pop some results. Most of the hubs are horizontal. Some docking options are vertical but, overkill for this sort of thing.
Check your monitor for a usb port and you might be able to just stick it there instead of a "base"
