vark
Greetings! I was trying to find the best place to talk about USB Flash Drive transfer speeds (particularly Write speed) and decided that AnandTech was it, so here we are. This issue no doubt arises with some frequency, but I didn't see a (very) recent post, hence the new thread. First, the particulars:
Board: ASUS Z97-E USB3.1 (about a year old, works perfectly)
O/S: Windows 10 Pro-64bit (Build 1511, I never opted for the 1607 "upgrade")
Flash Devices on hand:
Corsair Slider Voyager USB3.0 64GB
Corsair Slider X1 Voyager USB3.0 32GB
Patriot Vex USB3.1 32GB
SanDisk Cruzer Glide USB2.0 16GB
Most of the usage is to copy video files (mkv, avi, mp4) onto the drive(s) to plug into my Samsung 720p TV. I've happily been doing this for years.
Now the deal. My Corsair 64GB was beyond awesome, especially for the price. Though only a year old, it started to act up just before Christmas (random read problems both from the TV and PC, even after reformatting in NTFS and a clean "error check"), so I decided to replace it with it's little brother, the 32GB model. Disgusted with the write speed of the replacement, I got the Patriot 32GB and it's Even Worse. I'm including the old Cruzer as a benchmark (it's three years old and still works fine).
The Corsair 64GB typically has (had) sustained write speeds >100MB/sec with peaks >140MB/sec. (which is generally better than moving files on my SATA HDD). There's the odd file that confounded it and the speed would drop, but never, ever less than about 40MB/sec. Read speeds were even more astounding, but I rarely read from it. I used one of the two front panel USB 3.0 slots (both work equally well).
The Corsair 32GB model never starts it's write speeds >60MB/sec (usually ~40MB/sec) and rapidly drops to <12MB/sec, often bottoming out at ~4MB/sec. I've used the same USB3.0 slot(s) as it's big brother, as well as trying the back panel slots just to see if there's a difference (there isn't).
The USB 3.1 Patriot 32GB never starts >40MB/sec and rapidly drops to <10MB/sec, usually bottoming out around 6MB/sec. Additionally, it has this strange sawtooth pattern to it's writing, up and down between 4 and 12MB/sec. I've used both the dedicated USB3.1 slots and every available 3.0 slot with the same result.
The old Cruze 2.0 generally writes between 4 & 6MB/sec. No idea how many writes it's had, but it's A LOT, and it's still fine.
All of the Win drivers are up to date insofar as the driver search indicates that I'm using the most recent versions available. I've been through every USB related item in Device Settings and checked them all, just to be extra certain.
So, any idea what the [insert expletive] is going on, here? The usual answer is along the lines of "oh, well, USB is crappy and if you're getting better than 4MB/sec, consider yourself lucky" variety. Which hardly explains the sheer aweseomeness of the Corsair 64GB 3.0 model and it's blazing fast speed. It certainly doesn't explain why the new Patriot 32GB 3.1 unit is so dog slow.
Warmest regards from coldest canadaland!
