Hi guys,
I recently connected an external drive to my USB and it told me "This device would perform faster if you connected it to a Hi-Speed port." or something like that. I tracked the problem down to the fact that I didn't have an enhanced USB controller installed, or the proper USB Root Hub. I found the driver CD and put the files on, everything installed ok.
Now my problem is that all the devices are still registered to the generic controller and not the enhanced one in my device manager. I tried removing the generic but then my mouse and keyboard stop functioning! When I reboot my PC, it just re-installs the generic controller and I'm back to the same issue. I've got both set of controllers showing up in the device manager, how to I switch the default? There are no options in the enhanced one that let me set something like this.
any ideas?
I've got an MSI K8N-F board I think (at work right now, can't check specifics) running windows XP Home.
Thanks in advance
Regards,
Songix
any ideas?
Thanks in advance
Regards,
Songix
