thanks for the response. The USB port of the enclosure is not working. All the USB port of computer are working. I can attach usb pens and see them in the windows explorer
I was just hoping that there might be something else I could do other than change the enclosure.
I had the same problem on an enclosure. Took it apart thinking it was a loose solder joint but testing the joints showed that that wasnt the case. I think the enclosure usb controller chip just up and died. Had to use the firewire port which is still working.
