USB 2.0 Hub with a PS/2 input as well?
My laptop only has 2 USB 2.0 ports and no PS/2 ports. I'd like one solution which can accept a PS/2 input from my keyboard and has 3-4 USB 2.0 ports. Any suggestions?
You can probably get a USB hub with a PS2 port but it would probably be fairly expensive. I think a better solution would be to get a normal USB hub and use This to connect your PS2 keyboard. You can also get one that does both a keyboard and mouse for less than $2 more.
There are short cable adapters that plug into a USB port and have a PS/2 femaile connector on the other end. I have one somewhere, but can't find it at the moment.
Here's an example:
USB-PS2
This appears to be exactly what you're looking for. Note: I've never bought from this place before so I don't know how good they are.
