This might not be a very bright question.
I bought an internal DVD writer (IOMagic 16x dual layer)
I put it into an enclosue which I bought from here:
http://www.acortech.com/.sc/ms/dd/11106...DROM%20Enclosure%20SD-525U2ENC%20Black
I set the whole thing up and plugged the USB cable to my laptop
Now what do I do? How do i start burning DVDS?!
My laptop has only USB 1.1. So when I put the cable it gives a message that i dont
have the HI Speed USB controller. But I thought this stuff was supposed to be
backwards compatible.
If I insert the cable and restart, the comp refuses to go into setup. Even after plugging in the cable, the drive dosent show up in My Computer.
So basically after setting up the enclosure and DVD writer, I am not sure what to do now.
Any guidance or comments would be great.
Thanks
Thanks
