I'm running win2k on an Abit BG7, and all the drivers loaded fine with the default bios. Well, I wanted to use the 3:4 cpu/mem ratio with the low hardware strap, and found from this forum that I needed the latest BIOS to do this correctly.
I updated to the AX Bios, and now USB 2.0 and the Audio driver no longer work. I tried loading the new USB 2.0 drivers from the abit site, but I still get "The data is invalid" message when I try to install the driver.
I think what happened is this: I was using the old BIOS and used the windows update method to get USB 2.0 to work. I then flashed to the new AX bios, and it changed some kind of ID string to where the Windows Update drivers no longer recognize the USB 2.0 controller. Installing the Abit drivers didn't help because they can't be on at the same time as the old USB 2.0. So the question is, how do I remove the old USB 2.0 drivers obtained from the windows update? Am I even on the right track? Has anyone else encountered this problem????????????????? AAARRRRRGGGGGHHH!!!!!!!!
