Hi all,
I am currently using Windows 2000 on a Sony Z505-LE laptop. My issue is with a US Robotics 2410 wireless PC card. This card worked when I was using a Windows ME and Windows 2000 dual boot setup.
Now, after I formatted my hard drive and reinstalled only Windows 2000 Professional the card won't work. It shows up in my hardware device manager with a yellow exclamation mark.
If I click on the properties of this piece of hardware in the device manager, I see that the Device status says:
This device cannot start. (Code 10)
I have updated the driver for this device to the specifications of the US Robotics website (driver version 1.33.0.0) and I can see that the driver is loaded just fine.
Now, if I go to the Control Panel -> Administrative Tools -> Event Viewer(Local) -> System Log
I see three errors that seem to repeat:
1)
Type: Error
Date: 9/29/2002
Time: 3:54:16 PM
Source: Service Control Manager
Category: None
Event: 7000
User: N/A
Description:
The Cdralw2k service failed to start due to the following error:
The Service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
2)
Type: Error
Date: 9/29/2002
Time: 3:53:55 PM
Source: USR
Category: None
Event: 5002
User: N/A
Description:
U.S. Robotics Wireless Access 802.11b : Has determined that the adapter is not functioning properly.
3)
Type: Error
Date: 9/29/2002
Time: 3:53:55 PM
Source: USR
Category: None
Event: 5003
User: N/A
Description:
U.S. Robotics Wireless Access 802.11b : Could not find an adapter.
Also, if I uninstall the device in the hardware profile and restart the computer, Windows 2000 detects the hardware as new and picks the correct driver for the product but then when I look in the device manager, the errors remain the same.
BTW, I have all updates suggested by the Windows Update tool installed.
Can you think of anything else I can try?
Thanks!
1)
Type: Error
Date: 9/29/2002
Time: 3:54:16 PM
Category: None
Event: 7000
User: N/A
Description:
2)
Type: Error
Date: 9/29/2002
Time: 3:53:55 PM
Source: USR
Category: None
Event: 5002
User: N/A
Description:
3)
Type: Error
Date: 9/29/2002
Time: 3:53:55 PM
Source: USR
Category: None
Event: 5003
User: N/A
Description:
Thanks!
