Hi,
I have problems reaching my USRobotics router. The model is USR988000. My aim is to connect 2 computers (1 winXP, 1 MacOSX) to the internet. My first step in this proces is reaching the router from my XP machine. I am absolutely sure that my ethernet card is installed okay. (I can connect to my ISP directly). The tcp/ip protocol is installed correctly. (I can ping localhost and a manually configured ip address.) To pin the problem down, I'm doing all my testing without connecting the WAN port on my router to my D-link ADSL modem. So my ethernet card (3com Etherlink III, generic 3C509b) is connected with a straight through UTP cabel to Lan port 1 on my router. The led on my ethernet card is lit as well as the Link/Act led on my router. The power led is blinking once a second, the status led is not lit. Win XP tells me in a pop up that ethernet is active at 10Mbit/sec.
The problem is that when I manually configure my IP settings to 192.168.123.201 for my XP machine, subnet mask 255.255.255.0 and gateway 192.168.123.254 (the default) I cannot ping my gateway. ("destination host unreachable")
When I try to configure IP through DHCP (which is enabled by default in the router), my machine gets the rather strange IP address 169.254.164.224 assigned with a subnet mask of 255.255.0.0 and the gateway address is empty.
I read in the manual that I have to reset my router by unpowering it, hold the reset button and then connect power again, holding down the reset button for another 5 seconds. This gives me rapid blinking leds but they keep blinking forever. The router doesn't seem to reset and all I can do is upower and power it again.
I don't know if pinging is blocked by default but even trying to reach the router through http via IE5 with 192.168.123.254 doesn't connect me.
What am I doing wrong?
