- Oct 26, 2004
- 31
- 0
- 0
I basically built my own computer... After connecting all of the necesarry conections , I turned on the computer and I hear the fans from the CPU, Video card, and the PSU go on and immediately turned off after 1 second...
What could possibly be wrong? The LED from the motherboard is green (standby mode).
Would this be a power issue? Would this be a connection issue, cpu, memory, etc? Did i just send 1000 dollars down the drain? I'm terribly worried and would really appreciate some help.
This is the first time I build a computer in 4 years, so I dunno if i did anything terribly wrong.
Thank you very much.
Best regards.
PS: here are the specs:
Intel Core 2 Duo e6750 2.66ghz
GeForce 7950GT OC
Thermaltake 500w Pure Power Power Supply
Corsair XMS2 DDR 2 2gb memory
Hitachi Desktar 320gb SATA hard drive
ASUS P5N SLI motherboard
ANTEC Sonata SOLO case
Best regards.
GeForce 7950GT OC
