So I was using my computer and everything was fine for a few hours and all of a sudden I get a lockup. There was nothing I could do to gain responsiveness so i did a reboot by hitting the reset button on the case. My setup is as follows:
core 2 duo e6600 (dual core)
xfx 680i LT motherboard
mushkin hp2 4gb ddr2 ram (2x2gb)
western digital caviar sata 640gb hdd - main drive with windows
seagate 500gb sata 7200.10 hdd - storage drive
external western digital hdd - storage drive
asus dvd-rw sata
sapphire radeon 4870 1gb
asus xonar d2 soundcard
ocz gamexstream 600w power supply
I have owned the setup for about 1.5 years, with only the radeon / ram / soundcard being newer parts (got the radeon a few weeks ago and the ram/soundcard in august)
Now when i try to boot the computer (i have also cleared cmos so everything is stock) the POST says "detecting IDE drives..." but I do not have any IDE drives, my dvd drive is sata as well as are my hard drives. It sits on that "detecting ide drives..." for about 5 minutes, then it goes to boot, but whenever it tries to boot from anything it just then freezes and is stuck there unless i hit the reset button or flip the power supply power switch.
So far I have tried multiple hard drives, changed out the ram, tried booting with only cpu+motherboard+ram+graphics card+one hdd but with no luck. I suspect that something is wrong with the motherboard but i am not sure as i do not have another s775 motherboard to test with.
Any suggestions or help? Thanks.
asus dvd-rw sata
