Please help me.
Ok So I was trying to format C:\ on HD1
I have 2 HDs
My HD1 (40GB) had 3 partitions: C:\ D:\ E:
C:\ was WinME FAT32
D:\ was space partition FAT32
E:\ was WINXP NTFS
My HD2 (200GB) had F:\ NTFS
I formatted using the winxp disk on C:
While it was formating I went to take a shower and when I came back
It was INSTALLING WINXP on C:\ !!! and it became NTFS
I couldn't get out of it because it was already almost completely done.
I waited until it finished and when it did I immediately check my computer
AND I COULD NOT BELIEVE IT. My 200GB partition was gone!!!
It had all my backupped files. Copy of everything.
After the terrible sinking feeling,
I rebooted praying hard that it would come back
After reboot I could no longer access XP thru E:\ (My original install)
I was directed to the new C:\ Windows (XP)
After numerous reboots, I booted from the XP Install CD and attempted to
REPAIR E:\ Windows
I tried to fix the MBR, I have not much experience (I WAS REAL DESPERATE)
I THEN tried FIXBOOT and BOOTCFG
I Typed in BOOTCFG /add E:\Windows
E:\Windows was then added to boot select screen
There was two other options:
drive (forgot what it was left blank )
drive option: 2
After Doing this and rebooting I was able to select XP from either E:\ and C:
Booted up XP on E:\ (at least it appears fine.)
Still did not see my 2nd HD
I went thru XP Computer Management/Disk Management
and find it is unpartition (unallocated)
I want to desperately recover my lost partition. And I do not know how. As of right now its still unpartition or unallocated. This happen to me at such a critical time. I am a NOOB so I turn and now must ask or beg if there is anyway to restore the partition or at recover the files. Please help me.
I have 2 HDs
C:\ was WinME FAT32
E:\ was WINXP NTFS
REPAIR E:\ Windows
drive option: 2
