URGENT! Need Help! An Issue I've Never Seen
MixDJ
Ok, let me give you guys the lowdown.
A buddy of mine bought a new barebones pc.
He took the new one and put his hd and parts in it. It works fine.
Then, he swapped out his wifes old system for his.
This is where it starts.
He has a PC Chips cheapy chipset (m810LR) and when he put it together and booted it up, it worked fine aside from a few issues.
Well, my buddy being the budding tech, he figured the system drivers from the new bios disk would fix his issues.
Boy was he wrong. Nevermind he never called me to ask before he chose to do this. He could boot into Win2k before hand, and after that, he got a boot device error blue screen of death.
So, I've formatted, flashed the bios, and reset everything and formatted the hd's and low level formatted the main drive and it hasn't done anything to fix the issue.
I cannot install 98 or XP. Everything I try, I get an error in conjunction to the OS. A kernal error, a ntdlr.sys error (not valid), and another error in 98. Now I'm stuck at the bios and in DOS and can't install the OS.
Any takers on this issue? I've never seen it before and am clueless as to how to go about fixing it.
Any help would be appreciated!
Thanks in advance.
