Urgent Monitor Help
xFrosties
20
Hi there. So today I decided to buy a decent monitor since the one i'm using is quite old. My budget is about $350-$400 and here's what I am looking for.
A 120-144hz refresh rate
1ms response time
24in or higher
G-sync built in ( I dont even think its possible with my budget )
1080p/1440p res
At least 1 display port and 1 HDMI port.
Some monitors I have looked at are
Asus VG248QE - although I'm not a fan of the glossy plastic look of it and I think it is not G-sync compatible.
BenQ RL2460HT - I personally am looking for this kind of look to the monitor a matte black finish that is not too flashy. But this monitor is 60hz
Please recommend me a good monitor. I need to order it by today/tomorrow
Thanks!
corkyg
Elite Member | Peripherals
27,370
240
You left out important deciders: Size, and ISP or regular LCD. I would look at Dell as well.
