URGENT HELP!
n23sh
53
Yesterday I bought my new rig, but unfortunatly I have the big problem with it. I can successfuly install windows on it, but when I want to copy some files from my cd rom to my hard the BLUE SCREEN appeare and the system restart also when I try to copy some files in my hard. my parts of my system is:
CPU: C2D E4300
MainBoard: 965P-DS3P, rev2, F4 bios,
Memory: 2x1 GB, patriot, bus 800, 4.4.4.12,
HDD: Western Digital 320 GB,
VGA: Gigabyte 7600GT,
Power Supply: 580W
I never try to overclock my system up to now.
Please help me what can I do? :-(
ch33zw1z
39,631
20,219
Run everything @ stock speeds. Record the BSoD STOP error and possibly file name. check support.microsoft.com for what the STOP error means. Post back your results.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Originally posted by: n23sh
how can I post back my result. i just can post the error to microsoft, so?
He means so we can learn from it and/or continue to help.
P.S. When you send an error report to Microsoft, no one actually looks at it. The error types are only used for data analysis.
n23sh
53
it told me try to update my vga driver, but i already have the latest one. any other guide please?
ch33zw1z
39,631
20,219
what's the stop error lol
edit: what OS version r you using? xp pro @ sp2?
ch33zw1z
39,631
20,219
STOP ERROR!!!
anyways, try doing an uninstall/reinstall of your graphics adaptor. that can clear it up sometimes.
Cr0nJ0b
1,141
29
meettomy.site
I'll assume you are using XP Pro SP2, as that is the system I know best.
I would check your error logs, Control panel -> administrative tools -> Event log -->system.
See if there are any red lights saying things like "hard drive error" etc. Check the other logs too for odd reports of failures.
If that doesn't check out. Reinstall the chipset drivers.
If that doesn't fix it, then start moving stuff around to make sure that your IDE has a clear interrupt path. You can check the interrupts by going to the device manager and selcting view b--> resources by connection.
Look for stuff sharing the same interrupt as your IDE controller. you have probably a couple SATA controllers and a PATA controller. Try to move stuff around so that they are on seperate interrupts.
Also, if you have the Drive and ROM on the same controller try to move it to a different controller...so if they are both SATA, move on to the orange and one to the purple connector.
Basically, I'm guessing that you are getting an interrupt conflict when you write a bunch of data...either that or your drive has some bad sectors and is barfing on writes. The Event log should tell you if the drive is having issues, and the moving interrupts should fix a conflict there.
If this doesn't help, you will need to post more details about your setup...like type of CDROM, OS, patches...etc.
piasabird
17,168
60
Could be a bad video card.
Could be bad memory.
Active X?
Bad Power Supply. 4 pin plug? 24 pin power supply?
Chipset drivers?
n23sh
53
I descovered when the error occured but I don't khnow why. when I connect my hdd to yellow connector of my mainboard I have this problem, but when I connect it to purple connector i don't have any problem. my mainboard has only one ide port so i connect my two dvd rom to it.
