URGENT HELP WITH OUTLOOK
phattt
7
my OS got screwed.
it cant boot up anymore.
the data is still inside.
i need to retrieve the contacts and emails from my outlook.
they are VERY important.
i tried googling but none suggests anything about retrieving them from another PC.
please help.
all input much appreciated.
mechBgon
Oct 31, 1999
30,699
1) take ownership of the \Documents and settings\<username> directory you need to rescue stuff from
2) enable display of hidden files, and also system files/folders, in the Tools > Folder Options in Windows Explorer
3) search the \Documents and Settings\<username> directory for .PST files
4) import the Outlook.pst file into your working Outlook installation (File > Import/Export > etc etc). You may also want the Archive.pst file if important stuff was auto-archived there.
MrChad
13,507
Just to add to what mechBgon has suggested, your PST files should be located at \Documents and Settings\<username>\Local Settings\Application Data\Microsoft\Outlook (assuming you are using Windows 2000 or XP).
