You really think double sided tape will hold it? Ok well if it wont, I was thinking of getting some Artic Alumina at a local PC shop. Once I get it, do I just cover the GPU with this after its been well cleaned, and then just stick the CRORB on top of this? How long will it take for a permanent bond to form, where it will not fall? Thanks. Also, is it possible to use my video card in my PC without the stock HS for like 1 hour? I really need to do something and cant wait?
